Thread: Question for late (twin plug) distributor green wire in a early 911
    Feb 2005
    Montreal, Canada
    Hello,
    I have a late distributor that was converted to 12 plugs, now can you help me to connect the green wire to my 70S harness ? The wires coming at the distributor are a black and a black/purple wires.
    Should I cut the green wire before the connector and make 2 separate wires ?
    Thanks !
    JD
    1970S Coupe, Blood orange #1436
    1965 Coupe, Dolphin gray #1506
    R Gruppe #647 ; S Registry #1666
    Sounds like you have a magnetic reluctor distributor, are you using 6 pin CD boxes?
    Aug 2007
    Phila Pa. area
    The black and purple is for the Tack.
    Mike
    Mike
    Feb 2005
    Montreal, Canada
    Thanks Ed for the reply, I have a Aaron Burn converted distributor for 12 plugs. I'm using 2 x 3 pin CDI boxes with new Kroon harness for twin plug.
    Now with PMO but hopefully back to MFI soon when I will get te pump back from Gus.
    Thanks again for your help !
    JD
    You need to ask Aaron how to wire that.
    Feb 2005
    Montreal, Canada
    Thanks Ed, I was finally able to find new coordonate for him.
