Thread: transmission output flange cap o-ring 999-701-094-50
    I have a 902/1 in for service, destined for a '67 912. The output flange caps arrived without o-rings that were apparently installed in them, 999-701-094-50, and the o-rings do not appear to be included in the Elring seal kit. NLA from Porsche, and I don't see a spec for the o-ring dimensions in the parts diagram.
    Would anyone know these o-rings' dimensions? Were they installed with the Loebro caps, as well as the Nadella? The parts diagram seems to indicate Nadella only, but they also indicate the retainer spring clips are Nadella only, and this transmission arrived with spring clips. Cheers and TIA,
    Aug 2009
    SF Bay Area
    Quote Originally Posted by catelluseng View Post
    I don't have the specs but they were installed in both lobro and Nadella caps.They should be a common piece, though. Take some measurements and pick your supplier. Try JimmyT, he probably has them or knows the specs.
    Jim
    Kevin and Jim,
    Nadella flanges use thin tap-in caps without o-rings, and do not use retainer clips.
    Only the early Loebro flanges use caps with o-rings, and use the clips. I think JimmyT supplies o-rings with his Loebro caps.
    Jon B.
    Vista, CA
    Jon, Jim, thanks very much for the quick responses. I've a PM into JimmyT, hope to hear from him. If he has a business # I can call, please advise.
    Kevin
