Thread: 1970T wheel/tire/spacer setup...
    OK guys, I've read a ton of threads on the subject, but wanted a sanity check before I pulled the trigger.
    Essentially, the car is a 1970 911T (no flares) and I wanna run Group 4 Torq Thrusts - 15x7R rear and 15x6 fronts. On top of that, I'm hoping to run Avon CRZ66 rubber - 185/70/15 front and 215/60/15 rear.
    If my research is correct, the 215 Avon is gonna be a tight fit on the rear and require a 15mm spacer.
    Given that, two questions:
    1. Is the 15mm spacer thing pretty well known at this point on these cars? Meaning, go ahead and order them to be ready for the rolling stock? Or has it varied from car to car and I should wait to get the wheels and tires, measure, and then order?
    2. Who makes the best wheel spacers for such an endeavor?
    Thanks a ton guys!
    Jul 2006
    Corvallis, OR
    Elephant racing makes stackable spacers so you can get it just right. Do you have the stock wheel studs or longer? It can be a pain getting 215's to fit right. Are your fender lips rolled?
    72S, 72 3.5L Signal Green, 914-6 GT Signal Green
    Feb 2003
    Los Angeles
    H&R makes some nice wheel spacers and the larger size spacers are hub centric.
    https://www.hrsprings.com/products/detail/trak
    Scott's idea for the variable spacers from Elephant have helped me dial in my rear tires (15x7 911RFuchs). My left rear is still rubbing on big bumps.
    Remember that different tire manufacturers have different widths for the same 215 size. It will be trial and error.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
