Results 1 to 10 of 12
Thread: Oil leak guidance
    Dec 2013
    Connecticut/Florida
    Oil leak guidance
    I now have 99.9% of the kinks out of my 71S which was a nuts and bolts restoration and full engine and gearbox build. However, I have what seems to be at least a couple of oil leaks. The engine and gearbox shop have offered to take the car and fix without cost. Before I do that, and in the interest of learning, I thought I would see if I could fix first. There seems to be at least two engine leaks and also a gearbox link - blue color. Attached below are some photos. Seems like I would need to remove the heat exchangers yo get a decent look. Any advice ?
    1971 911S Coupe - Gemini Blue
    Dec 2013
    Connecticut/Florida
    Dec 2013
    Connecticut/Florida
    A few photos
    May 2014
    South East USA
    I know a long long term Porsche mechanic, he sprays this transparent clear film on his seams.
    He sprays it about 3 or more times, letting it dry and build up, and pretty heavy.
    He usually does it after a rebuild, and turns his motor upside down on the engine stand.
    He never has a leak.
    He even does it with every oil change at the big nut.
    (I’m just the messenger here).
    It appears to be Swepco oil in the transaxle , in my experience this oil essentially dissolves Yamabond type sealants , I'm not a fan . The one leak at the bottom of the trans - engine may be coming from the oil thermostat , oil pressure sending unit area . There are probably a hundred places for oil to leak on a 911 engine so good luck .
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    The best method for finding leaks:
    Pressure wash (really thoroughly)
    Let it completetly dry
    Genreously powder with French Chalk (or similar e.g. baby powder)
    Don't be shy (it washes off easily) I sometimes blow it with pressurized air to the hard to reach sports.
    Prepare Endoscope / Mirror Lamp etc. and go for a short drive (1-2 miles).
    You'll see where it leaks. Don't drive too far otherwise you won't see where it leaks.
    If you drive too far you won't see where it leaks
    Some times our cars leak when not used much. Getting things nice and hot might help.
    Getting things hot will absolutely not help , maybe some oil on the heat exchanger will burn away .
    Apr 2012
    Durham, NC
    I find this stuff effective. Obviously a thorough engine clean is necessary prior to use. https://www.amazon.com/dp/B002M4G24U...=auto+oil+leak
    Tom
    Sometimes it isn't the mechanics fault. I once had to do a flywheel seal twice (964) . (Porsche dealer seal) When it leaked again a conversation with Wrightwood, Rosemary suggested using old style SC black/brown seal. Solved leak!
