Results 1 to 7 of 7
Thread: 911S Pass side inner wheel casing
    Aug 2007
    Phila Pa. area
    Factory Pass side inner wheel casing, never mounted.Casing is for a 911 that uses oil lines to the front of the car. Picture shows the two Hoiles in the side panel for the lines to go through. I believe the holes are the only differences between a 911T or E part? $3000.00 plus shipping, Check or wire trans.
    Mike
    I don't currently need this (I hope)...but this is like hens teeth. Amazing condition. GLWS
    registry# 1283
    Dec 2003
    West Los Angeles
    Other difference is the threaded holes for mounting the oil cooler body.
    That is a real prize for a restoration shop to have on the shelf. GLWS
    techweenie.com
    Aug 2007
    Phila Pa. area
    up to the top
    Mike
    Aug 2007
    Phila Pa. area
    Bump it up
    Mike
    Aug 2007
    Phila Pa. area
    Bump it up
    Mike
    Aug 2007
    Phila Pa. area
    bump it up
    Mike
