Results 1 to 9 of 9
Thread: Blaupunkt Frankfurt Radio Package
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    Going trough my boxes of parts after finishing my 911 projects I've found a couple working radios that I would like to get off the shelves.
    First is a Blaupunkt Frankfurt 69/70 timeframe complete package for installation.
    The package consists of:
    - Working radio with correct knobs
    - Original recessed radio trim piece with very nice chrome
    - Front Radio mounting plate, which you can cut to create correct mounting spring clips of needed
    - Rear U-shaped mounting clip with fresh powdercoat
    - New sierra madre radio trim plate to put in your dash trim (cover it with vinyl yourself)
    - Used original working center speaker, with new clips for dash and screws. (Has a small hole, but still works fine)
    - New blaupunkt speaker cable, chassis mass cable and some small mounting hardware
    - New Din-connector box for adding a phone/mp3 external music player as input (not tested)
    - New modern powered antenna, that I was planning to mount under the dash
    Would like to get $400 shipped for the entire package <adjusted price>
    I have uploaded more pictures and a video of the radio (with different knobs and no faceplate) and speaker playing here: https://drive.google.com/drive/folde...usp=drive_link
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
    Front Radio mounting plate will not fit for early 911
    GLWS
    Jan 2007
    Netherlands
    Quote Originally Posted by enoz05 View Post
    GLWS
    And that is why I made the remark that you need to cut it, so you can still use the spring clips on the side.
    Rgruppe #674
    Quote Originally Posted by 911_2.2T View Post
    Even than, it won't fit
    Jan 2007
    Netherlands
    Reduced to $350 shipped
    Rgruppe #674
    Feb 2012
    Netherlands, Leiden
    Would this be correct for a 1968 911 SWB Alex?
    Jan 2007
    Netherlands
    A code on sticker refers to 69/70 year
    Rgruppe #674
    Feb 2012
    Netherlands, Leiden
    Ok thanks!
    To be correct you need a serie Y (1967/68) or serie Z (1968/69) radio
