Results 1 to 8 of 8
Thread: Classic ATS 15x6 on SWB??
    Feb 2004
    Texas Gulf Coast
    Hi all,
    Anyone know if original classic ATS wheels in 15x6 would fit a SWB?
    -Jay
    Seabrook, TX
    '68 911T project -The Rat
    '74 911 3.0 EFI Twin Plug toy
    '80 Weissach 3.2 S.S. Grocery Getter
    '70 914/6 GT vintage race car
    I run 15X6 Group 4 alloy steel wheels with 185 Pirellis and have no issues.
    https://www.group4wheels.com/store/L...els-p248645143
    I wouldn't imagine the offset is much different.
    Sep 2012
    Surrey - UK
    Can't help with the tech info but I do like ATS Classics on an early 911.
    Ralph
    1970 911E
    Instagram @ralph.k.w
    Early S Registry #2728
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Think they were standard on some 73’ Porsches. So, should be a good fit.
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    67 911 de Luxe, 356 B silver metallic / brown interior, ( buck skin really ) 67 PORSCHE [ Reuters ] 912, Crystal blue, black interior, 72 T, Silver metallic/black interior, appearance group,factory AC.
    Sep 2012
    Surrey - UK
    Quote Originally Posted by jmz View Post
    Hi all,
    Do you mean ATS Classics or ATS Cookie Cutters?
    I thought you meant Classics when I posted the picture above but here's a SWB with 6" Cookie Cutters:
    Ralph
    1970 911E
    Aug 2009
    SF Bay Area
    Hi all,
    Not all "SWB"s are the same. Porsche extended the front hubs on 68s to better accommodate wider wheels. 68s came with 15 X 5 1/2 wheels instead of the earlier 15 X 4 1/2s. the ATS wheels will fit on all SWBS, kinda.......You should replace the original wheel studs with ones that are, at least 5 mm longer. Even longer would be better. Wheel studs through 1967 were 35mm and are just not long enough to get the stud to stick out past a lug nut, when using any alloy wheel. Also, 68s all ran a 7mm spacer on the rear hubs with much longer wheel studs.
    Dec 2013
    Connecticut/Florida
    Just to show look of cookie cutters
    1971 911S Coupe - Gemini Blue
    Oct 2018
    Orange County, California
    Would 6” Classics have same off set as 6” Cookie Cutters?
    1957 356A Cab Condor Yellow
    1970 911E Targa “CONDA G”
    1970 911T3.2 “Meatballs”
    1972 911T2.5 “AWBRGN”
    1972 911T Targa Glaserblau
    1976 911S Talbot Yellow
