Thread: 73S - What am I grounding?
    Anyone know what this (double) wire is grounding? Comes from above the fuel filter on a 73S.
    Any reason not to connect to location shown behind filter?
    Thanks for the help.
    Dave Reu
    Member #3949
    1973 Silver Metallic 911S
    Should be the ground for your license lights.
    Jul 2006
    Corvallis, OR
    License lights is the single ground. The double ground is coming off of the main harness. Not sure exactly what it grounds at this moment but I'd definitely hook it up.
    72S, 72 3.5L Signal Green, 914-6 GT Signal Green
    Thanks both.
    Quote Originally Posted by Longballa View Post
    Correct. For what it's worth they are together with these two wires a red w/ black stripe (auxilary starting relay?) and a pink w/ white (speed switch?). Presumably one ground each? Maybe the reason for the occasional back fire under engine braking??
    Name:  Speed Switch Cable.jpg
    Consider it connected.
    GO RAMS!
    Dave Reu
    Member #3949
    Rear window defroster. All those ungrounded circuits, sure is a careless mechanic.
    Mr. Mayo,
    I couldn't figure why in the world a harness would be coming from a not so ideal location. Duh! The rear window defrost.
    Fantastic! Truly gratefully for yours and every ones help on even the little things like this.
    Dave Reu
    Member #3949
