Thread: Early SWB ignition switch with dome lock - 2 different types
    Senior Member 68S_SK2's Avatar
    Mar 2006
    Munich, Germany
    Hello everybody,
    Haul and I are discussing following topic:
    Here are pictures of 2 different SWB ignition switches with dome lock for FL keys.
    When did it change from the early convex tip style with longer produding key lock cylinder to the later, shorter, concave tip style?
    Thank you for your help.
    BR Claudius
    Attachment 603394
    Hello, Can I see the left switch complete?
    Mar 2006
    Munich, Germany
    Shorter, concave tip, later style
    Mar 2006
    Munich, Germany
    Convex tip style with longer produding key lock cylinder, earlier style
    And the Part Numbers? may be 901.613.101.00 (1965-1968) 901.613.101.01 (1968-1969) can you check? You have a good question
    Mar 2006
    Munich, Germany
    Both have the early 90161310100 casting number.
