Results 1 to 2 of 2
Thread: FS: Restored LWB 911 & 912 Pedal set. $300 with a core.
    May 2006
    Riverside CA 92505
    This is a restored pedal set that fits 68 - 73 911 and 912. It will also fit SWB cars that are converted to use a dual circut master cylinder. This pedal set was is excellent condition with mimimal rust prior to restoration. Housing, shaft, clutch tube , brake rod, and accelerator crank are powder coated. The housing and pedals are powder coated for maximun rust protection. New sorings and bronze bushings are used. The pictue shows both a 911 and a 914 clutch pedal as this set will fit either car. The correct pedal will be supplied. Price is $300 with core exchange or $450 outright.
    sent you a PM
