Thread: Weber carb removal
    Weber carb removal
    I need to remove my weber carbs so I can send them to be rebuilt. How difficult is it to do as a DIY? 1969 911T. Thanks!
    May 2014
    South East USA
    It’s pretty easy.
    But go real slow, and try not to drop any nuts or washers.
    Easier, Especially if you use a magnet on a stick now and then.
    And have a stubby wrench, even if you cut one shorter.
    Some of the hard nuts can be reached from the top with a long socket.
    There are some you have to feel your way, just go slow.
    And I should add…your job will be 75% easier if you wear one of these LED headlamps.
    Removing the crossbar brackets will help with access
    John Schiavone
    Connecticut
    Thank you so much, great advice!
