Size:  104.4 KBName:  IMG_0740.jpg
These grommets match the sheet metal hole and the cable ID where the three cables are seen in the center of the picture. Found the grommet part number in another post and they are cheap, but you have to pay $7 shipping.
Used some super lube on the cable OD and they were pretty easy to install, just make a 3” loop under the dash before pushing the cable through the grommet.
Ordered extra, but did not need them. Have three sets, each with three grommets. If you would like a set for $3, PM me.
Refurbished the control panel with spray satin black, new knobs, and blue and white label making tape. Not perfect, but a lot better than before. The blue is more of a baby blue, the light washed out the color.
The three pics need to be rotated 90 degrees clockwise. Advise on how to do that?
Steve
