Thread: Removing the Muffler on a 1965 911
    I would like to remove the Dansk muffler on my 1965 911 in order to have it recoated. It doesn’t look like there is a lot of room in order to remove/replace the muffler without hitting the painted rear panel. Is there a way to remove/replace the muffler without having to dismantle the rear panel? Thanks for any helpful suggestions.
    Apr 2011
    N.Calif., south of SF
    Best to remove the rear panel by first removing the rear bumper guards, L & R. 3 allens a side I recall.
    Then 2 muffler straps holding it in place by 2 larger allens. Then the muffler bolts; 2 on a side. Be sure to support the muffler after taking the straps off.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Quote Originally Posted by Haasman View Post
    Thanks for your advice. That is what I have decided to do.
