Did Porsche make a twin coil bracket? If so I would like to buy one. Or do folks just cut and weld the single brackets together.
1970 Irish Green 914-6 w/2.2S
www.reSeeWorks.com
I put a common bolt through the inner flanges.
Paul Abbott
Early S Member #18
Weber service specialist
www.PerformanceOriented.com
info@PerformanceOriented.com
530.520.5816
What Paul says above seems to be a good method. Check out the twin coils on the white 1974 RSR in this post and you can see the common bolt running through both coil brackets: https://forums.pelicanparts.com/pors...lug-coils.html
There are some custom brackets out there too… guess it depends on the look you’re after.
Thanks guys.
I think I’ll have both cut, welded, and sent out for new zinc plating.
I don’t want the center bolt. Just not clean enough.
www.reSeeWorks.com
Wasn't there a fellow from New Zealand that was making a repo of the factory set up?
Thanks, Rick
Paul
1969 ex-South African RHD Tangerine 911T . 1970 ex-Southern Californian LHD Conda 911T 1955 Series 1 86" Land Rover (original Australian CKD … very slowly re-building) 1987 W124 230e
(long term paid up member)
Factory built racing cars used this type of coil bracket, it has an open slot across the center, and...it's made of titanium. this photo is the David Piper 917. the twin set up are 2 standard steel single brackets stacked together. Looking for other examples to post...
Ernie W
member of Early 911S Registry
If you care about weight reduction and ease of maintenance, I make them out of aluminum to save weight over titanium.
917 Spyder Coil Brackets Al Coil Brackets, $83.78 each
I'll take 2 Jimmy.
www.reSeeWorks.com
