Thread: Parking / Emergency / Hand Brake Light On
    Dec 2018
    Los Angeles
    Hi All:
    I am chasing a new (and oh-so-fun) issue on my 1971 911T. The parking brake light on the combo gauge is illuminated.
    The light is constant on (not flashing) and has gone out a few times while driving on the freeway . . . only to come back on a turn (without braking).
    Just the facts, ma'am:
    • The brake fluid tank is 80% full.
    • The master cylinder is relatively new.
    • The gauges were recently refreshed.
    • Wiggling and pressing down on the parking brake handle does not impact the light.
    • Parking brake handle is fully released.
    • Wiggling the wire underneath the parking brake mechanism does not impact the light.
    • Brakes function as normal.
    • Everything was fine until one day I parked, shut the engine off, came back, fired her up, released the parking brake and the light didn't go out.
    Any thoughts on where I should start my hunt? Thanks in advance!
    Moved to Technical. Will be watching this thread with interest.
    Peter Kane
    '72 911S Targa
    Apr 2003
    Portland, OR
    Unplug the electrical connector from the master cylinder to determine if the MC switch has gone bad.
    Harry
    Member #789
    2009 MB C300
    Senior Member sweetE's Avatar
    Dec 2002
    Highlands Ranch, CO
    You might want to check your battery.
    Dale Thero S Registry # 200
    Dec 2018
    Los Angeles
    Quote Originally Posted by HarryD View Post
    Thanks, Harry. Because I have a euro car, I don’t believe I have a wire that plugs up to the MC.
    In an event, no wires are connected to the MC (and no wires are readily available in or around the MC).
    Without a wire connected to the MC, the gauge light is on. Figure this suggests that my issue is with the switch under the e-brake lever in the center console.
    Dec 2018
    Los Angeles
    This one has been solved. The wire coming off the e-brake switch got crimped under the new Recaro I recently installed. DOH.
    It's always the easy ones, right?! . . . Thanks for your help, everyone. I really appreciate it.
