Thread: Cavitation Sound Behind Dash Area
    Junior Member scottjk's Avatar
    Oct 2023
    Seattle
    I purchased a 1973 RS backdate on a 1983SC chassis. I'm getting a strange cavitation type liquid sound coming from the dash area during some corning and braking. The oil cooler is still in the passenger wheel well with new braided lines running on the right side rocker area. Ideas?
    Aug 2017
    el sobrante ca.
    maybe the air inlet water catch is pluged and holding water
    Senior Member 30westrob's Avatar
    Mar 2016
    SE Pennsylvania
    The 83 911SC had Vacume powered boosted brakes using a booster in the rear of the trunk. I would start my search there. Rob
    Might be a check valve in the brake booster system. I have a friend who rebuilt a motor and did it again searching for a noise and it turned out to be the brake check valve.
    I used to get this noise from my fuel pump in my 81
