Results 1 to 10 of 13
Thread: 2.7 Starter Kit: Case, Heads, Rods, Cylinders, Cam Towers, Chain Housings
    Senior Member beetle08's Avatar
    Oct 2010
    Seattle, WA
    Revised Ad. This is a 2.7 Engine Kit. Motor was removed w less than 5K on it. Customer came in for 3.0 Swap. Low mileage motor was removed, disassembled, all parts cleaned, checked, and rebuilt as detailed below. I purchased parts after they were machined, cleaned, and rebuilt as indicated. Moving in a different direction. Kit includes following:
    7R Magnesium Case: 901.101.101.7R Hot tanked, cleaned, plugs, removed, galleys cleaned, oil squirters installed. Case checked, machined, and and is STANDARD. Machine work completed by NW Connecting Rod Service. Small corrosion on front of case as shown, otherwise in excellent shape.
    2.7 S Spec Head fully rebuilt: 911.104.342.2R These are matching set (1-6) with 2/75 Date codes. New guides, springs, valves, etc. Machine work completed by NW Connecting Rod Service.
    2.7 Crank Needs to be polished.
    2.7 Rods: Porsche Rods: Balanced and Rebuilt
    Cam towers: Need to be cleaned.
    Chain Housings and Covers.
    Update: 2.7 Used Cylinders, Pistons, and wrist pins! All fins intact. Clean up and re-ring!
    Included: Use Oil pump, intermediate shaft, and studs.
    All parts located in Seattle, and have been kept in dry storage. All items have been packed in bubble wrap. Please note this will be heavy. Buyer pays shipping or I can deliver CASE w/in 150 miles for $150.
    Price: $7500 Link to Photos HERE.
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 912-6 TR Tribute
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    1991 Porsche 964 Carrera 2 3.8
    "if you see a fork in the road, PICK IT UP!"
    Oct 2010
    Seattle, WA
    Revised Ad. Please delete.
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    Oct 2010
    Seattle, WA
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    Oct 2010
    Seattle, WA
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    Oct 2010
    Seattle, WA
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    Quote Originally Posted by beetle08 View Post
    Will split up items.
    Case
    Cam Towers
    Chain Boxes
    Rods
    Heads
    Please list individual component pricing per forum rules. Thanks in advance.
    Peter Kane
    '72 911S Targa
    Oct 2010
    Seattle, WA
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    Junior Member
    Nov 2023
    Tucson, AZ
    Looking to build an 2.7 RS Spec motor so am interested. Can't seem to message you though as I'm a recent member to this board.
    Quote Originally Posted by azcarguy View Post
    Until you have 10 posts, you’ll have to share your contact info (email/text info) publicly…
    Peter Kane
    '72 911S Targa
    Junior Member
    Nov 2023
    Tucson, AZ
    Thanks for the heads up, and noted.
