Results 1 to 2 of 2
Thread: '73 High Pressure Fuel Line
    As my car has already had the original lines replaced, I'm looking to just replace the rubber portion of the high pressure line from the pump to the fuel filter.
    Couple of quick ones:
    1. Is the ID on the high pressure fuel line from the pump 7mm or 7.3mm?
    2. If 7mm, will the one shown below from Pelican work in the high pressure application? Opinions welcome. Cloth braided is preferred.
    Dave Reu
    Member #3949
    1973 Silver Metallic 911S
    The discharge line is 7mm, we used to use 7.2 but they stopped making it. That discharge line goes to (crimped fitting) a steel line that goes up thru the frame rail and from there another short piece of 7 carries it to the inlet of the fuel filter.
