Thread: Piston type 906 Mahle 81 mm
    Feb 2016
    Bordeaux FRANCE
    Smile Piston type 906 Mahle 81 mm
    Hello,
    Looking for one or two piston in good used condition as one of mine as self ignition top damage.
    Piston type 906 Mahle (80,9X mm) and 3 rings (oil ring groove is 3,5 mm)
    Let me know what You have !
    Will post picture to help the search
    Same as the one illustrated in #11 of this tread: https://www.early911sregistry.org/fo...-69S-906/page2
    J-R
    I have these, 10 new pistons, 6 with rings pins and clips. Like the Boy Scouts say, be prepared.
    Feb 2016
    Bordeaux FRANCE
    Thanks for your reply and offer.
    10 new pistons are a little too much at the moment !
    That's actually a good deal for serious racer but finding one good used is more what I need at the moment.
    Feb 2016
    Bordeaux FRANCE
    Up,
    A good used 81 mm mahle piston 3,5 mm oil ring groove around ?
    I can trade with 81 mm mahle lower compression ratio than 906 with 4 mm oil ring groove.
    Or 80 mm 906 and 2 L S 67/68 or 69 used original pistons.
    Yes all kind of originals !
