Thread: swb front window cowl nice corners
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    sold
    nice window corners
    threads for the flap mountings are intact
    asking 200€ +actual shipping costs
    Aug 2017
    el sobrante ca.
    the nice thing about this piece is trhat the weatherstrip channel is probably the correct 20mm wide
    the reproduction cowl chanel are 18mm
    the rubber goes in .... but it is squeezed... and when the hood is closed it raises the hood to cowl alignment/ flush
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by bob joyce View Post
    yes i never quite understood why RD uses different gauge (thicker) sheet metal for most of there parts than the factory used. i assume they scanned the inside of there sample and did not subtract the extra wallthickness in CAD--wrong data milling.... but you can`t beat cut and paste anyways
    Aug 2017
    el sobrante ca.
    cut and paste indeed............
    lol
