Thread: '67-'68 door top aluminium trim
    I'm wondering how exactly the aluminium trim was attached to door tops in '67-'68 S (and L). Is the door top itself exactly the same - just trim added to it?
    The other trim related is question relates to aluminium trim in dashboard inserts: I have seen cars both with alumium strip with both sides of the vinyl inserts and then some with trim only in upper side of the trim. How should it be in late '68 S (SWB)?
    Thank you already in advance
    Br,
    Aki
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    maybe this is of any help
    https://www.early911sregistry.org/fo...638#post986638
    several years ago i sold NOS 68s/L door tops with plenty of fotos...if you can`t find the ad--i will maybe see if i can find them on my computer
    These are very helpful - thank you moito!
    Aug 2017
    el sobrante ca.
    the long lower knee bump is specific for 911S and 911L
    these pieces have the provision for accepting the trim piece
    other model knee bumps will not accept the trim piece
    Ok - this makes sense and explains the different observations. Thank you!
    Quote Originally Posted by bob joyce View Post
