10% off listed sales.
I have reorganized my collection of early Porsche parts and have reduced several new offerings.
Contact me if you see something you want or even if you are interested in a related item. I probably have it. I am selling the following now:*
1. (5)3-pin CDI units 12 MO warantee-$425, with rebuildable exchange-$275.*
2. (5) Weltmeister-or equivalent gated short shifters-Porsche body(05 or 06) and custom Seine gate-$375. Add $55 for knob and $19 for new boot. Shifter alone $275.
3. (2)Carrera cooler kit and (4)Carrera ($950) coolers-(good shock mounts,*
short oil lines, and mounting hrdwr). Carrera oil cooler w short lines $650. Flexible AN16 Aeroquip oil cooler lines,thermostat and fittings($550)-complete front to back setup for 70-1. Oil plate cooler kits-$250.*
4. Mocal Oil Thermostat AOT2 -$100. AN12 fittings for Mocal-$20, SC/Carrera Oil*
Thermostat-911.107.163.OR (good threads)-$250.*
5. 1970-2 911 rubber oil Lines and fittings(inquire)
6. (1)180 MPH (mechanical) Carrera rebuilt speedo-$750.*
(1)2.2L 911E (70/71) $10500-$12500 Mag. Stacks/Throttle bodies etc and MFI and fuel pump
(1)2.4L 911E (72/73) $6500-$8500 Mag. Stacks/Throttle bodies etc and MFI and fuel pump
(2) 2.4L 911E (72/73) (inquire) Plastic Stacks/Throttle bodies no MFI pump*
(10)2.4L 911T (72/73) $6500-$8500 Plastic stacks and MFI pump and fuel pump
8. PARTIAL MFI SYSTEMS OR PARTS eg.-injectors(6 untested $375 or
Tested $500), fuel consoles $750, MFI fuel pumps rebuilt $350, air boxes-$550, etc. e.g. 1972/3 2.4L 911E stacks and throttle bodies-$2800.
9. (3)1972 911S oil console-$650, (5)1972 911T oil console-$525.
10. Volvo Turbo fuel pump/regulated for MFI applications(3 port direct substitute for*
Bosch 001)-pressure and flow tested-$350
(3)1972 911 $350-850(mint), (1)sporto $350, (5)1966-1971 911 $350-$750(mint).*
12. (1)1969-1973 headlights with bezel $150, two-stage rear window switch $150.
13. 911 (1969-1973) mufflers-(1), flowmaster (1/1)x2-($250),$,OEM Porsche $475.*
14. Early fog light switches-new rubber knob and symbol $250-working light. Cigarette lighter with rubber knob and excellent symbol $200.
15. New clutch plate for 1972 915 (225mm) $175.
16. New reproduction aluminum license panel with sport muffler cutouts(1969-73) from Dansk $125. Early 911 jacks –good to excellent condition – used $150-175.*
17. NOS Sway-away rear swing arms- $325 shipped.
18. TTG 1969-73 fog lights-restored Hella TN2,4&6($450,$350&$375), Used $450-250. Fog light covers-$135 Give your car that special look. Inexpensive aftermarket fog lights $150-350. Free reproduction mounting brackets with purchases over $450.*
19. Good starter motors 69-73 125-200.*
20. Rebuilt (new o-rings/sealed) MFI electric fuel pumps-flow tested to spec.-$350, Carb.-$350, and CIS-$325. 914 2L Jetronic Bosch fuel pump $250. Bosch fuel pump rebuild $350+parts+materials. Includes flow and leak test data.*
21. Gold Porsche lettering for 1972 911S targa (TBD).
22. Pair of rear bumpers(69-73) in painted Bahai red -mint $575 .
23. Rear bumper S molding(pair) $250.
*Included are the following: pump support bracket and AL spacer, oil breather plate with
cold start thermostat, oil line to pump, fuel console with bracket and filter, 6 fuel lines, 6 fuel injectors, free moving MFI pump with good pulley, throttle stacks, bodies, crossbar, and linkages, air filter housing, air filter, and snorkel, flapper box for 72/73 air intake.*
Pictures available upon request. ( X) indicates units available. email:*pgeorge911@aol.com, Telephone 952 835-9969
Old 10-25-2023, 2:54 PM
Report Post
Old 11-09-2023, 08:49 AM
