Thread: Tire size on a swb
    Jul 2003
    Jacksonville Beach
    Tire size on a swb
    Hi all.
    Building a 67S hotrod with a little oomp. Hoping to have about 200-220 hp when done.
    Using 4.5 fuchs on the front and deep sixes on the rears. What tire sizes would be ideal for this set -up ?
    1962 356 S Cab gone
    1967 911S Coupe
    2008 RS60 Boxster gone
    1973.5 911T targa soft window Gone
    Runge 008 Gone
    2002 996 TT x-50 Gone
    2016 Boxster GTS pts gulf orange
    1969 912 SWT pts green
    Can I be FRANK with you ?
    Live everyday like it's your last .
    Eventually you'll be right.
    My guess would be a 185 on the front and 195 maybe 205 on the back.
    You’ll need to do some measurements with your wheels, wheel wells and potential tires.
    -Doug
    2022 Carrera 4S Oslo Blue
    1977 Martini Edition 924
    1989 Lancia Delta Integrale 16V
    You might want to consider these to maintain the proper look all around. You could run 195s on all four corners, which I find is the sweet spot for a powerful SWB. My '67 had a 2.8SS that made 272hp at the crank.
    https://www.early911sregistry.org/fo...ored-by-Harvey
