Thread: Compression #'s on 73E engine
    What would the experts think normal compression numbers would be on an excellent running, well maintained 73E 2.4 MFI with 150K miles?
    Appreciate your thoughts and time.
    Bobby
    Bobby Smith
    member #299
    1973 914/4 2.8 ltr. (FTD winner 2008 Charlotte Parade) (sold)
    1973 911 "Orangello"
    1973 914/6 GT 3.2 "Crystal Blue Persuasion" (sold)
    2011 Boxster Spyder
    1973 911 E "E GO" Metallic Green
    Hi Bobby, I only do leak down tests which I would expect to be 15% or less and the more even across cylinders the better. But cranking compression should be in the 120 psi range (give or take maybe 15 psi either way) and again, the more even the better.
    Thanks Ed. Hope you're doing well. Really enjoyed meeting you at the 2008 Parade in Charlotte. I recently acquired a 73 E that had been in storage for 6 years. I'm resurrecting it. Running incredibly well after a ton of work. Will check compression soon to get a base line. Thanks for your expert advise.
    Bobby Smith
    member #299
    2011 Boxster Spyder
    Finally got around to doing leak down/compression test. Engine is in incredible shape. Less than 6% on leak down and all 6 cylinders are
    right around 150psi. Excellent numbers.
    Bobby Smith
    member #299
    2011 Boxster Spyder
    Quote Originally Posted by Bobby Smith View Post
    That is indeed awesome for an engine having done that many miles and sat around for so long...take a lottery ticket
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
