Results 1 to 10 of 11
Thread: Looking for best hood strut replacement options
    I need to replace the hood struts (again) on my 1969 911T.
    I have had 3 early 911's and 1 912 and all have been plagued with replacement struts that don't last as long as one would like.
    I am curious as to different options on non stock ones that might last much longer and hopefully still retain the OEM look.
    Thanks in advance.
    Peter
    1969 911T Coupe Blood Orange (Vivy)
    Jun 2012
    London, Ontario, Canada
    There are a variety of mechanical hood struts (e.g. Rennline). The only issue is that if you deal with a shop that doesn't realize that the hood needs to be pushed back up to release and they try to force it down, they can bend the hood or the hinges. I keep a sign in my frunk for such occasions and haven't had any issues.
    Ravi
    Early 911S Registry # 2395
    Those hood shocks are available in normal, or heavy duty. I have had luck with 2 HD, or one of each.
    Nov 2010
    central Va
    In 50 some years of ownership, I've found that a broom stick works best.
    Senior Member McOtto's Avatar
    Apr 2023
    Denver, CO
    Quote Originally Posted by Perry911 View Post
    I need to replace the hood struts (again) on my 1969 911T. I am curious as to different options on non stock ones that might last much longer and hopefully still retain the OEM look.
    I installed Stabilus 9369BL heavy duty (430N) hood struts (911-511-331-00-M117) about 18 months ago without any issues since then: https://www.pelicanparts.com/More_In...11-331-00-M117
    1972 911T Targa
    1985 911 Carrera (with circa 1988 RUF 3.4L 260 hp DIN Engine Kit)
    Aug 2017
    el sobrante ca.
    ski pole works
    I used to have a boxful of failed struts, they are gas filled I think, and are not very reliable. Maintenance item
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    Thanks in advance.
    Peter
    Some info here on using 959.511.333.00 https://www.912bbs.org/forum/threads...6solved.59376/ and some info here https://www.early911sregistry.org/fo...76-hood-shocks
    registry #2072
    Sep 2018
    Netherlands
    It's a pity they are such a pain to replace.
    1970 2.2S Elfenbeinweiss
    2002 996 TT Midnight Blue
    Member #3833
    I bought a black carbon fiber mechanical hood prop from one of the online retailers and it works great. It took me only a few minutes to install it in my hotrod 911 and it’s been significantly better than replacing gas struts every couple of years.
    Stretch
    Registry # 3063
