Thread: Battery not charging 1968 911 L
    Junior Member
    Feb 2023
    Charge lamp goes out and blue wire reads 13.8 volts but battery is not charging. Battery measures 12.6 with engine running.
    Cleaned and measured ground and red terminals at alternator.
    Nov 2009
    Cecil pa
    If engine rpm is near 1000, double check reading @ 1800.
    Junior Member
    Feb 2023
    Sorry it's been a while,
    Thank you for your message I will check it...
