Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: VIN Plate cleaning
    Oct 2016
    NW FL
    Question VIN Plate cleaning
    My VIN plate is in need of attention. I have gently washed it to minimal success. I have used a scotchbrite pad with little success. Any suggestions?Name:  IMG_0920.jpg
Size:  235.4 KBName:  IMG_0920.jpg
    Senior Member smiles11's Avatar
    Oct 2021
    Northern California
    I would suggest dry ice.
    Aug 2005
    Bucks Co., PA, USA
    Have you tried Nevr-Dull?
    ESR #1474
    Oct 2016
    NW FL
    I have not heard of nevr-dull. Will give a shot. Thanks
    Mine were well preserved, but I use Semichrome polish. Don’t think yours will make it back to like new.
    Nov 2010
    Montana
    Leave it Alone. That is called PATINA and adds Value.
    Oct 2016
    NW FL
    Depending on the results I achieve, the PATINA may be the way it stays....
    Senior Member Sixtyseven911's Avatar
    Feb 2015
    Los Angeles
    I can second the use of Simichrome....and a little elbow grease
    ESR # 3177
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Tewfiks View Post
    looks like it has been sandblasted at some point of its life.
    3M used to make a spray on aluminium cleaner, acid based. I used to buy it at auto paint supply stores. Used to prep aluminium parts before priming with zinc chromate.
