Results 1 to 7 of 7
Thread: Engine sheet metal hole for linkage
    Guys
    See photo of engine linkage alignment and pass thru rear SM hole
    Mine does not align ? This is carbs if that matters
    Cut new hole or different component?
    Thanks for assistance
    FrankName:  IMG_8617.jpg
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    What does it look like if you reverse the bellcrank? Are these all original parts including the manifold or some combination of repops? You should not need to cut a new hole.
    Oct 2010
    Southern Ca.
    I believe the piece you pictured is for an MFI engine , you need one for carburetors .
    Thanks Richy & Ed
    So am I correct that the bell crank piece needs to be changed for pivot on opposite side to align with hole ?
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Oct 2010
    Southern Ca.
    No , you need to source the correct tin .
    Thanks Richy….
    Looks like I need to post on WTB …
    Anyone have this SM piece ?
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    May 2006
    CT
    Frank
    I may have the tin you need. Let me know if you are still looking and I'll check my stash.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
