Results 1 to 10 of 10
Thread: Question re the Dating of Early Porsche 911/912 Windshield Wiper Assemblies
    I am looking at a windshield wiper assembly for an early 911/912. See Photo # 1. It doesn’t have a Porsche part # on its base like the early assembly base shown in Photos #s 2 and 3. Instead, it simply has the name Edschol stamped into the base. See Photo # 4. Can someone please explain why some early wiper assembly bases had inscribed Porsche parts numbers while others just had the Edschol stamping? Thanks.
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    I do not know when the part number was introduced, but early linkages only had the “Edscha” stamped.
    https://www.early911sregistry.org/fo...ghlight=edscha
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl", swapped 1:1 for a
    10 997 racing green awd „gustl“
    erwin_loves_polo
    Thanks Haul. I came to the same conclusion. Are there any photos of the earliest linkages, one for the 64 and early 65 911s?
    Jul 2014
    bavaria
    please do have a detailed look at the previous listed thread link -
    1st and 2nd executions of the linkage systems are en detail .. .. .
    erwin_loves_polo
    Quote Originally Posted by prs356 View Post
    Check the thread of 300090. He posted his mechanism,
    Richard
    Can you tell from the attached photos the approximate date of the wiper assembly? I don't have any additional photos or access to the assembly. Just the photos. Thanks.
    It looks to me that this mechanism can not be taken apart? I don’t see clips?
    Richard
    Here is a photo of the underside of the assembly. It looks similar to 300090's. The fittings for the wiring are not the same.
    This is an October ‘65 assembly
    Could it be 64 October
    Richard
