Results 1 to 10 of 19
Thread: LH front oil cooler for 1972 2.5 ST
    Senior Member matteo68's Avatar
    Jul 2021
    Bicester, UK
    Can anyone tell me if the LH front oil cooler as fitted to the 21 2.5 STs in 1972 with part number 901.107.045.00 was the same as the one fitted to the ‘68 911R or was it just the RH ‘69-‘71 S cooler (with part number 901.107.046.00) with the brackets cut off and welded onto opposite sides please?
    I have found this drawing of the 911R oil system on here which shows the LH cooler with the above-mentioned part number but it is incorrectly labelled as “oelkuhler rechts”, same as the RH one (but the latter has the correct .046 part number):
    Can anyone help? A picture of the cooler fitted to a genuine ST would be great.
    ESR #4098
    ‘72 T Coupe (donor car for M491 2.5 SR)
    '72 S Coupe (2-owner tangerine unicorn)
    Looking for 915/00 gearbox #7120022
    In this picture of the 72 ST parts spread out on the ground, you can see a bar and plate style 911R oil cooler. The R’s have 26mm fittings and the 72 would have had 30mm fittings. I’m sure production coolers were used along with trombone coolers, especially in the rally cars where radiators were too fragile.
    Jul 2021
    Bicester, UK
    Thanks Gordon.
    I’ve seen that picture before and had assumed that might have been the case but wasn’t 100% sure, although as you say all the parts appear to be from the ‘72 Competition Parts list (the car is a ‘72 MY 911 S)
    You’re right about 30mm fittings and helpfully Carpoint make an M30 bar-and-plate style LH cooler so I think this is the answer for my project:Name:  IMG_7790.jpg
    ESR #4098
    Yes Matteo left and right coolers were the same with different attaching brackets as you have deduced.
    Clyde Boyer
    1997 993 Twin Turbo
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Jul 2021
    Bicester, UK
    Quote Originally Posted by BOYER73S View Post
    Are you absolutely sure Clyde? Have you seen any pictures of one in situ? I’m inclined to go with Gordon’s assertion as this seems to make sense to me and put myself out of my misery!
    ESR #4098
    Quote Originally Posted by matteo68 View Post
    No Matteo I have not.
    Just to be sure we are on the same page I believe the left and right in 72 were the same cooler except for brackets but I missed the query re the same as R coolers, apologies.
    Let me check with the oracle Hugh he may have pics, he's got pics of everything else
    Clyde Boyer
    1997 993 Twin Turbo
    Sep 2009
    UK
    Matt. Look in the "Another Hot Rod " ST thread by Flunders. Pretty sure i had seen it mentioned..... or was that a dream.
    Jul 2021
    Bicester, UK
    Hi Dave
    It’s been a while since I read Flunder’s excellent thread so yes I’ll do that but if I recall his car was a ‘71 ST (although he did reference the differences in the ‘72s as well in several posts).
    Matt
    ESR #4098
    Jul 2021
    Bicester, UK
    Dave
    Flunder’s post #6 covers the LH cooler but is inconclusive as to whether it was a R type or a serial RH one with the brackets reversed:
    https://www.early911sregistry.org/fo...nother-hot-rod
    Matt
    ESR #4098
    Jul 2021
    Bicester, UK
    As no-one can say for sure (or prove to the contrary), I’m going with the R type cooler which Gordon highlights in the competition spares period photo.
    ESR #4098
