Results 1 to 10 of 14
Thread: Recommended engine builders
    Hi Everyone,
    I have an engine from a 69T that I want to build into a 2.5L Short stroke or similar.
    Could you please recommend any reputable engine builders that could do this for me?
    I don't mind shipping it anywhere in the states so location not so important...
    Zain
    Senior Member rac390's Avatar
    Apr 2018
    CT
    Hi Zain, Automobile Associates in Canton, CT can definitely do that for you. Scott McPherson, their engine builder is one of the best.
    Rick
    Apr 2004
    35,000 ft
    you might not mind shipping it anywhere, but a year later, don't you want that engine builder to be available should you have any questions or concerns. I would think you'd want to start with some local firms, if none of those check your boxes, yes Auto Associates is great, and there are some other great firms elsewhere in the country.
    Senior Member rgupta250's Avatar
    Jul 2020
    Orange County, CA
    Quote Originally Posted by blucille View Post
    Not to mention the post-build tuning and adjustment which always are needed.
    1971 911T/ restoring to S-spec Coupe / Gold Metallic on Black
    1995 911 C2 / Guards Red on Cashmere Beige (Sold)
    Jan 2024
    PNW
    Zain, let us know where you are.
    Guys, thank you for your replies.
    Im based outside of the US so will be shipping the engine in, no other way. There isn't a single shop close by that has experience with this.
    I completely understand the benefits and general wisdom of having a local shop do it but unfortunately not an option for me...
    Thank you for the recommendations and please keep them coming.
    Best,
    Zain
    .... the other option being to import all the parts required and build locally myself and/or with the help of a local engine shop which would 100% never had any experience with any porsche engines...
    Im pretty sure I could manage that way too but really want to avoid it because it would require a whole lot of time that I don't have
    Jan 2024
    PNW
    You might be able to avoid custom fees on the return. Oregon and Delaware don't have sales tax for needed parts. You might try Rothsport in Oregon as they have dyno.
    Oct 2008
    Burford, ON, Canada
    Even knowing your country would help. I know a guy near Toronto ON, Canada
    Scott McKeown is building my 67S to a 2.5 spec. PM me and I'll give you his contact info. He's in PA just around the corner from Delaware Porsche. I understand Peter Dawes in PA is also first rate.
    Name:  scott engine one.jpg
    Name:  Scott Engine two.jpg
