Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Need help finding valve stem that fits early deep six wheel
  1. #21
    glaverbel911
    Guest
    XWX
    The original "tube type" XWX' tires are identical to the new Michelin repro's. Right down to the ply count. The only difference is a different DOT # and there marked "tubeless".
    I still use them on my 73' S. Coker Tire sell's them for about $200 ea.
    The only way your going to find the "tube type" is by finding original mounted, unused spare's. But I would recommend using them only for show purposes if you ever locate any.
    Robert.......
  2. #22
    6Shooter
    Guest
    Early Fuchs & valve stems
    The valve stem I've been using are the same ones used for the VW (wide 5 bolt pattern) steel wheels. I think that they are for a 0.625" hole. I think that they are the TR415. I've been meaning to double check... sorry. Hope that it's not too late to help.
  3. #23
    a911s
    Guest
    TR415 valve stems
    I went to my local Discount tire and looked at their TR415s, but they appear to be the bulb at the end type, not the wide tapered variety.
  1. Rubber valve stem, deep six?
    Last Post: 04-28-2023, 11:03 AM
  2. WTB Valve stem supports for Fuchs wheel
    By mikez in forum For Sale: 911 Parts
    Last Post: 03-30-2011, 04:52 PM
  3. Valve stem help
    By surf in forum General Info
    Last Post: 05-14-2010, 04:08 PM
  4. valve stem for fuchs rim
    By vintage83 in forum Technical Info
    Last Post: 07-01-2008, 09:08 PM
  5. tubeless valve stem in deep 6 question
    By john walker in forum Technical Info
    Last Post: 03-18-2007, 03:29 PM
