Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: mfi problems surprise surprise
  1. #11
    BOYER73S
    Guest
    Re: Backfireing
    The backfiring is definately exhaust so much so I think I have ruined some baffles in the muffler.
    The microswitch is often mentioned as a problem how can I test if it is working or not?
    Clyde
  2. #12
    Roland Kunz
    Guest
    test
    Hello
    OK there are some test procedes. One done on every servic is you open the lid and rev the engine on the throttle abouve 3500/min then you press the microswitch with the finger and the engine shoulddrop to idle and then rev up to 1000 and drop again cycle untill you release the switch.
    Backfires in the exhaust are to rich MFI pumps and a leak in the exhaust who will add some oxygene.
    It also can come from bad valve or cam timing and fronm wrong setet MFI pump timing.
    Some fine crackle in theexhaust is normal
    Grüsse
  3. #13
    BOYER73S
    Guest
    Re: test
    Roland,
    Tested the Microswitch and it works every time however when I disconnect the wire from the microswith and render the system useless the car no longer backfires at all and all I don't have is the tacho flying back to zero and back up again.
    Might the problem be in the transducer or the the solenoid on the pump. Sounds like too much oxygen getting in somewhere.
    I am getting out of my depth I think.
    Clyde
  4. #14
    devond
    Guest
    Dan,
    Could you email me a copy of the MFI setup instructions as well. I'm pulling my hair out trying to get my 73S right.
    Devon
  1. '73T three minor problems I could use some help with
    By kilodawg in forum Technical Info
    Last Post: 01-16-2008, 08:08 PM
  2. MFI problems
    By tom dance in forum Technical Info
    Last Post: 08-16-2007, 01:46 PM
  3. Transmission Surprise!
    By Aircool in forum Technical Info
    Last Post: 05-17-2006, 09:30 AM
  4. 73 MFI Problems
    By gunnar in forum Technical Info
    Last Post: 04-01-2003, 08:59 AM
  5. Problems with 73 radio
    By caproader in forum Technical Info
    Last Post: 09-17-2002, 09:15 PM
