That makes sense. In the 1973 model year, the front fender cooler was an option. It was a trombone cooler in '73, but was not standard equipment, even for the S models.
So is there a trombone style oil cooler that will hook up to the '72 oil lines?
Jim Dunham
Registry member #3303
PCA Member 1987025103
1972 3.0L RSR Tribute DE Speed Yellow
1972 3.2L RS Tribute Blood Orange
1976 911 Backdate to longnose Desert Beige
1975 911S roller
1982 911 Outlaw (in build) Blue
2005 Ford GT with 5.0L Coyote V8 dry sumped
1973 240Z
I run a 2.0S High Comp. with just the engine oil cooler, even with 35C or driving to the metal on track it does not go over 210F.
However, the oil pump is a big one and am running Motul 300V 15w50.
O-G 26 - Early911S 2407
Thanks Ed - wow, I have not seen you since 1993 Parade. I see Aase makes them too. I may put in a shunt line to just connect the cooler lines in front until I sort what to do. Running a 3.2L in my '72
Jim
Jim Dunham
1975 911S roller
1973 240Z
The trombone is insufficient for a 3.2. You will need either a 28 tube brass or a later radiator type.
Sometimes the trombone will do it... depends on ambient temp, whether it has A/C, and driving style.
BTW: The RS loop cooler is available from Porsche.
I have the 72 lines mocked up now with a later trombone cooler and it looks like it will indeed work with some minor tweaking and new bracket fabrication. just clears the battery box. I'll run it to completion and post pictures.
Jim Dunham
1975 911S roller
1973 240Z
