Results 1 to 2 of 2
Thread: Optima battery vs OEM
    911scargo
    Guest
    I'm reassembling my 73S to original. Although it will be a driver, I want to show it a couple of times this year (Rennfest in Atlanta is the biggest event.
    The old batteries are shot. Performance products recommends 1 Optima battery installed on the driver's side, on it's side. I know this would significantly cut down on front compartment/battery box corrosion. However, for looks and performance, I would prefer two correct size, maintenance free batteries. The OEM batteries are the old cap/fill style. Any suggestions/help?
    911SRegistry
    Guest
    Some early 911 owners have installed a single Stinger brand sealed battery. They report a spec. of 800 CCA's. You could buy two and have that "stock" appearance without the acid look. Performance wise, they're about $175.00 a piece. A single Optima (also 800 CCAs) is about $125-$135. Mind you, two 800 CCA batteries wired in parallel is still 800 CCAs. The factory batteries were fairly puny (something like 300 CCAs?).
    Do a search in this forum for some previous discussions on the subject.
    Regards,
    Sherwood Lee
  1. Optima Battery losing fluid
    By red911 in forum Technical Info
    Last Post: 09-16-2012, 09:08 PM
  2. Optima Battery
    By 67S in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 04-03-2011, 12:16 PM
  3. Optima battery question ofr 911 SC
    By Sacto S in forum Other Porsche Passions
    Last Post: 01-15-2011, 04:10 PM
  4. Optima Battery
    By RTincher in forum Technical Info
    Last Post: 10-27-2005, 07:47 AM
  5. Optima Battery mount
    By mwalker09 in forum Technical Info
    Last Post: 11-21-2001, 02:07 PM
