Results 1 to 4 of 4
Thread: engine upgrade/modification
    thback
    Guest
    What possibilities are there to upgrade the specifications of a 2.4S engine, without changing displacement (to the popular 2.7)? Engine should be used for normal street use (no track) and therefore minimum sacrifice on reliability.
    Tom
    racea911
    Guest
    You could certainly use some pistons
    that have some decent compression ratings.
    thback
    Guest
    ..you mean
    the 2.2S pistons? Which I heard should be "cut-off" at the underside because of the stroke?
    T.
    (thanks)
    racea911
    Guest
    I think buying JE Pistons would be a much better bet
    and probably cheaper than trying to find some old 2.2S pistons in excellent shape and then modifying them to fit your 2.4 (if that is even necessary). The JE Pistons are about $1000 brand new, and they will be custom built to your exact specs. They are reported to be better quality, lighter weight and stronger than the OEM ones. A couple of the JE pistons engineers are Porsche guys and are involved with racing 911's.
    I am going by what one of my very good friends is telling me.... He is a very reputable mechanic too, I'm not just talking "local hero" either.
  1. The Canary: Engine upgrade 2.0 to 2.2
    By kav in forum Technical Info
    Last Post: 09-04-2013, 11:07 AM
  2. FS: 234hp `72 2,4S engine with RS upgrade
    By oldschool-performance in forum For Sale: 911 Parts
    Last Post: 01-08-2013, 09:59 AM
  3. 1966 engine upgrade?
    By setho in forum General Info
    Last Post: 12-30-2012, 09:33 AM
  4. 2.2S engine upgrade to RS spec?
    By IPF in forum Technical Info
    Last Post: 03-07-2010, 03:36 AM
  5. 2.2 T engine mild upgrade
    By zaza in forum Technical Info
    Last Post: 05-10-2005, 02:50 AM
