Thread: Air bleed screws
    72narrow
    Guest
    Air bleed screws
    Hi,
    I have '72 S with MFI.
    Could you give me an idea how the air bleed screws work.
    I understand they control the quantity of the inlet air only at the idle speed. But according to "Check,Measure,Adjust", we have to sunchronize them at 3000 rpm. ????
    Thanks advance.
    Roland Kunz
    Guest
    Bypass on the trottle bodys ?
    Hello
    Do you mean the bypass screws at the throttle bodys ?
    Grüsse
    72narrow
    Guest
    Re: Bypass on the trottle bodys ?
    Hi,
    Air bleed screws are six screws mounted at the bottom of the intake stack.
    Thank you
  1. H1 Screws
    By jaudette3 in forum Technical Info
    Last Post: 01-16-2013, 10:02 PM
  2. Replies: 13
    Last Post: 06-05-2011, 03:26 PM
  3. Brake rebuild/bleed system problem
    By Allen Henderson in forum Technical Info
    Last Post: 11-10-2008, 08:13 PM
  4. '67S Brake Bleed Screw Torque Specs?
    By Bob Schaefer in forum Technical Info
    Last Post: 06-09-2008, 11:09 AM
  5. MFI Air Bleed Screw Sizes
    By roblav in forum Technical Info
    Last Post: 05-19-2005, 05:03 AM
