Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: SSI's
  1. #11
    Rick Cabell
    Guest
    SSI heater boxes
    I have had a personal tour by John Danials of his complete facility. Very impressive. Without question,he has MFI boxes for the MFI cars. I saw racks of them. What a sight!!
  2. #12
    CBOYER56
    Guest
    Re: SSI heater boxes
    Please tell me where do I get them!
    Clyde
  3. #13
    Rick Cabell
    Guest
    mfi boxes
    I was going to refer you to Stainless Systems directly,but they won't sell to you direct. You have to be a dealer. You can e-mail me- eurotech@together.net I will get them for you if you like.
  4. #14
    Roland Kunz
    Guest
    Re: mfi boxes
    Hello
    The additional heating is used for cold wheater driving and lowering the emmisions at the cold phase.
    Porsche found out thata aged rubber boot beetween the aircleaner and the thermostat lowered the WOT output.
    Ageing was messured by WOT cyceling. The underpressure sucked the rubberhose to a lower diameter.
    So on most RS the rubber boot was removed.
    At each inspection you have to check the timing at 6000 then go further on to check if the ignition cutout works. While doing that keep a eye on the rubber hose. I fixed that problem for the winter drivers with a internal steel spirale like in the red heating hoses.
    All others drive open tube without the preheating system.
    Grüsse
  5. #15
    CBOYER56
    Guest
    Re: mfi boxes
    Has anyone with a 2.4S with Bosch fuel injection actually got a set of the SSI heat exchangers with the extra tube for the hose from the hot air regulator housing. I am still yet to be convinced that SSI exchangers do exist in the correct form for these cars
    Clyde Boyer
  1. Feeler for new SSI's
    By 21window in forum Technical Info
    Last Post: 11-17-2013, 04:37 AM
  2. WTB: SSI's for 1970 2.2L
    By Sugarfootfarm in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 04-13-2013, 07:14 AM
  3. Where to buy SSI's
    By 911_2.2T in forum For Sale: 911 Parts
    Last Post: 03-22-2008, 04:05 PM
  4. FS: SSI's
    By lechon in forum For Sale: 911 Parts
    Last Post: 02-26-2007, 01:55 PM
  5. SSI's ?
    By larry47us in forum General Info
    Last Post: 02-24-2004, 09:02 PM
