Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Steering wheels
  1. #11
    david w
    Guest
    I found a NOS 380 mm steering wheel from someone in Indiana. I purchased two leather wheelskin kits and laced them myself. It came out great and has a nice fat grip. The only problem is that the wheel is closer to the dash than I would like( about 2 inches.)
    Does anyone know of a spacer or hub that will move the wheel closer to me?
  2. #12
    GeorgeK
    Guest
    RS Wheel
    Hi David,
    Yes you can put a spacer. Not easy, but I have done it.
    The splined part is riveted to the wheel itself. You drill out the rivets, find a mechanic workshop to turn you a spacer, then re-rivet the splined hub to the wheel with the spacer. Works OK if you repaint the spacer in semi-gloss black.
    GeorgeK
  3. #13
    david w
    Guest
    Thanks GeorgeK. How large of a spacer did you install? How thick?
  4. #14
    GeorgeK
    Guest
    RS wheel
    Hi David,
    The spacer is about 1 inch (2.5 cm). It makes a big difference for me, but it
    will depend on your build. Basically if you drive spiritedly, there is no thing as
    too close, as long as you don't risk hitting your chest in a crash (the spacer built that way will NOT collapse). Aesthetically, 1 inch is OK, hardly noticeable.
    GeorgeK
  5. #15
    david w
    Guest
    Thanks George K
    I will let you know how I make out.
  1. 914 steering wheels
    By mepstein in forum General Info
    Last Post: 08-15-2013, 04:40 AM
  2. Steering wheels
    Last Post: 02-03-2013, 06:28 AM
  3. 911/356 steering wheels
    By 911s55 in forum Technical Info
    Last Post: 04-14-2008, 09:26 PM
  4. FS: Steering wheels
    By 70SATMan in forum For Sale: 911 Parts
    Last Post: 10-24-2006, 05:05 PM
  5. oe steering wheels
    By joelrkaplan in forum Technical Info
    Last Post: 03-17-2004, 05:27 PM
