Results 1 to 2 of 2
Thread: Upper strut mount bushings
    mcguillc
    Guest
    I need to find a source for the upper front strut mount bushings on early chassis cars-as you know, they don't have the caster/camber plate, just a hole in the fenderwell. Any ideas out there?
    adgx
    Guest
    strut mounts
    I damaged the upper bushing on my 70T as I was removing the struts. Mine have a hole with 4 bolt holes around it so that you can adjust slightly by moving the bushing housing and retightening. New ones (when I found them are $135-$150) I bought one from Parts Heaven for $25. It looks brand new.
  1. 901 transmission mount bushings ???
    By Greg D. in forum General Info
    Last Post: 05-07-2017, 04:26 PM
  2. Upper strut mount bushings
    By Merv in forum Australia
    Last Post: 08-15-2013, 03:08 PM
  3. Replies: 6
    Last Post: 07-30-2013, 12:48 AM
  4. Where to find transmission mount bushings for '66
    By jaldeguer in forum Technical Info
    Last Post: 11-17-2012, 12:18 AM
  5. FS: Upper strut mount kit
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 05-21-2009, 08:32 AM
