Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Batteries
  1. #11
    maybe sonnenschein uses the term "dry fit" on 2 different batteries? One a sealed liquid, the other a gel cell? I know that the ones I'm running are indeed gel cells...I'm on my 2nd set of them, opened the top of one of the first set. No liquid inside, but a true gel. So, consider me confused here. Yeah, my cost was roughly the same as bulldog's, so when I saw the $220 per pair price, I flipped.
  2. #12
    Dec 2002
    Birmingham, MI
    Well, after reading the endless early 911 battery scenarios here and on other boards, I made my choice.
    I bought a Odyssey 1200 battery today for $169 at a local Batteries Plus store. It was in stock and fully charged. Since it's a leakproof gel battery it can be mounted sideways in either box with some room to spare. Very nice battery with brass posts and a metal casing, I installed in driver side and removed lead to passenger box.
    Since nobody has said they noticed a handling difference with one batt vs. two, I chose this (cheaper and lighter) route over Sonnenschein. I have an Optima 6V in my 356 which works well and fits perfectly, but their 12V was too large for the 911 box. The setup seems to work great with no mods necessary, but I can't road test since the weather isn't ready for my car yet.
    Here's a pic of a similar install (on passenger side).
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
  3. #13
    The posts pointing inboard make me nervous...perhaps wrap some cut down innertube over them as an insulator...something to cut down the possibility of a short? That's the reason the factory placed the rubber caps over the + posts on the original dual battery set-up.
  4. #14
    Dec 2002
    Birmingham, MI
    Good Idea.
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
  5. #15
    Goldmember ttweed's Avatar
    La Jolla, CA
    Originally posted by JCR
    I bought an Odyssey 1200 battery today for $169
    Since my battery boxes in the '73 track car are long gone, I got an Odyssey PC925 dry cell that I'm going to mount in the smuggler's box to save some weight over the large Optima red top I've been using. Dimensions are : Length 6 5/8", Width 7 1/16", Height 5 13/16", with 470 CCA and 925 Pulse Cranking Amps.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  6. #16
    How much wt. do you save over the Optima?
    And, how does the ability to crank when cold compare to the Optima?
  7. #17
    La Jolla, CA
    Randy-
    Haven't put them on the scales, but I would say the Odyssey weighs a good 20 lbs. less, maybe more. It is half the size. It has half the cold cranking amps, too, but it's enough to turn over the 3.4 liter, 10.5:1 compression motor in the coldest weather we have around here (which is rarely freezing), and the car isn't a daily driver.
    TT
    Tom Tweed
    R Gruppe #232
    Read my surf novel!
  8. #18
    admin_old
    Guest
    The Optima is around 35 lbs. Not sure if that's 20 lbs. more than the Odyssey, but at 15 lbs., that would be quite light. In cold climates (near 32ºF or <), I would suggest a battery with a high CCA.
    Sherwood Lee
  1. Batteries
    By 71-911T in forum Technical Info
    Last Post: 02-12-2015, 12:57 PM
  2. Batteries
    By billm in forum Technical Info
    Last Post: 09-13-2011, 01:20 PM
  3. 70 911 batteries
    By kissov356 in forum Technical Info
    Last Post: 05-23-2011, 05:56 PM
  4. More than 2 batteries up front!!
    By mjk911 in forum Off Topic
    Last Post: 11-13-2008, 07:16 AM
  5. Batteries
    By lilacRS in forum Technical Info
    Last Post: 08-27-2001, 10:32 AM
