Results 1 to 2 of 2
Thread: oil tank vent
    Member, Human Race wit61's Avatar
    Jan 2003
    Pennsylvania, Northeast
    oil tank vent
    For those of you with K&N conversions for your carbs, what did you do with the oil tank vent hose ?
    http://www.classicvelocity.com
    70 911T Targa
    70 911E
    73 914
    If you go flying back through time and you see somebody else flying forward into the future, it's probably best to avoid eye contact....
    admin_old
    Guest
    The easy way is to clamp a K&N type oil breather cap onto the end of the hose or just shove the breather hose into a plastic juice bottle.
    The better way (I think) is to direct blowby and oil vapor into an intermediate catch can to separate the oil, then plumb the fumes into the air intake. K&N housings have a inlet port for this purpose. You can get fancy and use spun alumimum catch cans. There are also polyethylene containers for such purposes. See Summit Racing. I used a Pik-a-Part windshield washer reservoir and attached it to the system with PCV hose and grommets (from the auto parts store). A nice touch is a drain valve to recapture the separated oil.
    Sherwood
  1. Gas Tank Vent tubing
    By Dmill in forum Technical Info
    Last Post: 05-10-2022, 06:43 PM
  2. WTB Gas Tank Vent Chamber
    By 69S-S/R in forum For Sale: 911 Parts
    Last Post: 06-17-2012, 12:28 PM
  3. Clearing a plugged early SWB gas tank vent
    By Neil '67 911S in forum Technical Info
    Last Post: 03-21-2010, 07:59 PM
  4. gas tank vent tubes, 1973
    By gmaltby in forum Technical Info
    Last Post: 11-29-2007, 08:21 AM
  5. '68 911 fuel tank vent pipes question...
    By 72tii in forum Technical Info
    Last Post: 01-29-2006, 03:17 PM
