Here's a 1971 color chart, including interior options:
Shawn,
Below is the link to the auction. It ends today.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2417781523
Actually, the rods were different in the "S" motor too, I believe. They were nitrated, while the "Normal" engine rods were not, and titanium rods from the 906 could be ordered as an option. Not a big difference, I suppose, and if rebuilding one today I would use Pauter rods anyway...Originally posted by garth wagner
All that would be left would be the S pistons.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
PCA National DE Instructor
Read my surf novel!
TT,
I believe you are right. Was there any significant advantage to the nitrided rods that would make it critically important when rebuilding a normal 67 to S spec?
Also, what would a set of Pauter rods cost?
From where?Originally posted by ttweed
Does 2.0, 2.2 and 2.4 share the same rod length?
The 2.0 and 2.2 share the same rod length since they have the same stroke. The 2.4 however has shorter rods due to the increased stroke of the crank.
Bobby
71' Olive 2.2E Targa / Early S #491
I've always considered the glass to be half full...that is until I reached middle age and realized that it is actually half empty.
I would not say "critically" important. Nitrating is a surface treatment to increase fatigue strength and wear resistence and reduce the possibility of cracks propagating. Shot-peening the rods and cryo-treating them when they are reconditioned may have about the same effect.Originally posted by garth wagner
TT,
Haven't bought any lately, but I would guess around $1200/set, similar to Carrillo, possibly a little cheaper, since they are their main competitors.Also, what would a set of Pauter rods cost?
TT
Tom Tweed
R Gruppe #232
Read my surf novel!
From the factory. Titanium connecting rods were a listed option for the '67S at the dealer, if you were willing to wait for a special order car. Incredibly cheap, too, compared to what you would have to give for a set today, if you could find them.Originally posted by beginner
From where?
TT
Tom Tweed
R Gruppe #232
Read my surf novel!
ttweed,
I found someone who has a good used set of early S nitrided connecting rods from a 2.0S that is asking $500. Is that a fair price? Also, what is the lifespan of a notrided connecting rod? Do they tend to break down after a certain mileage?
garth-Originally posted by garth wagner
I would have to defer to someone who has more immediate knowledge of the used parts market to say if $500 is a fair price. However, if I was considering using them in a rebuild, I would want to know whether they have been tested for structural integrity and reconditioned or not. Fatigue and wear are the enemies of metal parts, and any used part is susceptible. If they have not been crack-tested, checked and measured for spec by a competent machine shop, then reconditioned, rebushed and balanced, you will have to add the cost of that operation to the bare cost of the parts in considering their value compared to a new set of forged rods.
That said, the stock rods are excellent pieces and can go many hundreds of thousands of miles in a stock motor without any problems. For racing purposes, in a high compression engine revving over 7800 RPM routinely, I would want the Carrillo or Pauter rods and bolts.
TT
Tom Tweed
R Gruppe #232
Read my surf novel!
