Results 1 to 10 of 16
Thread: Fuel gauge....
    Fuel gauge....
    Hello All,
    I want to check if my fuel gauge is functioning 100%. I can't seem to pump to full. About a whisker shy of 4/4, I get fuel spilling out from the below.
    Is there a way to ground the sender, besides removing it and inverting it? I just put in a new gasket. The old one was too thick, the new one seems to help but hey... Blame me for wanting to be perfect! Haha....
    Thanks!
    Sprint.
    I'm not sure you'd want to remove the sender/float assembly again...but one way to test is to move the float up & down while it's out of the tank, have somebody watch the gauge. An analysis tip given to my by a pro...
    No more vapor smell.. Don't want to mess with the seal again!!!
    Hehe.. The new seal fixed all the ugly fuel smells Katie had. No way I want to pull it out again! And the seal was expensive to boot....
    Was wondering if I can ground it like on my VWs and watch it deflect... Hehe...
    Fill 'er up.
    I filled my tank yesterday...wound up with the needle *just* under the 4/4 mark......
    On the other hand, when I fill my Toyota, it goes "over" the full mark. So...which is better, really?...the conservative or the impossible?
    Per
    Normal
    Sprint Star,
    My needle also does not go to the top of the full gauge when the tank is full. It's normal.
    The most important thing is that the needle shows empty accurately!
    Hoho... Mine drops from 4/4 to 3/4 too damn fast for me to believe.... Anyway, what kind of mileage are you getting? My '67S hardly gets 15mpg.... She damn thirsty!
    Sprint.
    Dec 2002
    Birmingham, MI
    My needle fills to just below the full mark.
    My car has Webers, I get similar mileage
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
    Hehe... Are we talking US or UK gallons here? Opps... I think I"m getting only 12MPG on my Webers... *groan*
    Sprint.
    How hard are you driving it?
    Sprint,
    Are you doing alot of city driving and/or are you driving it hard? It makes a big difference. The Peter Morgan book says that a hard driven 2.4S will only get appr 15mpg - and that's with the MFI set-up. Webers are suppossed to be worse.
    If you are hung up on mpg, buy a small lightweight 4 cylinder car for day to day jaunts, and only drive the 911 for fun. Better yet, buy a 356 or 912!
    With my 73' 2.4-S the very best was... In 5th for a full tank at the speed limit coming down the 5 on a holiday Sunday ... Just-a tick over 20MPG
    The worst, of course, is at the track... just about 9 if I'm lucky
    Usually about 15-17 around town...
    We'll see if the new motor makes a difference one way or the other...
  1. FS: VDO NOS Fuel Gauge
    By John Straub in forum For Sale: 911 Parts
    Last Post: 11-23-2013, 08:18 AM
  2. Wiring stock fuel gauge to fuel cell; need wisdom.
    By jameshtaylor in forum Technical Info
    Last Post: 11-10-2010, 06:18 AM
  3. 66-67 fuel/Temp gauge
    Last Post: 11-23-2008, 06:58 PM
  4. Fuel Gauge
    By kissov356 in forum Technical Info
    Last Post: 06-06-2006, 01:42 PM
  5. VDO Fuel gauge
    Last Post: 07-03-2005, 12:26 PM
