Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Rear brake rotors for '67S
    A simple question: where do I get rear brake rotors for a '67S? I believe they're NLA -- so I'm looking for NOS kicking around somewhere (or even a used pair with plenty of life). I haven't seen any on ebay. Any clues appreciated. Thanks, Bram.
    Goldmember ttweed's Avatar
    La Jolla, CA
    Last time I checked they were available from the dealer, but be prepared to choke on the price. The '67-68 rear rotors only fit those two years, and it is not worth it for the aftermarket suppliers to jump into that narrow market, so the factory bits are all there is. I think they were around $300 each. I decided to surface mine since there was room to do it within spec.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Apr 2003
    Portland, OR
    Hi,
    I can cut your search in half. I have one slightly used rear (10.3 mm thick)for a pre -68. If you are in the 48 states, $30 includes shipping by UPS.
    Let me know.
    Harry
    Member #789
    2009 MB C300
    Hey Harry........
    If the original poster does not want that single rotor, I'll take it!
    If TT says they are still available, then they are. I heard they are NLA. I have one extra set, but owning 3 SWB S cars I would be nuts to part with them.
    Woooops, wait a minute........If it measures 10.3 mm thick, then it is not a "S" vented rotor!
    La Jolla, CA
    Keep in mind the last time I checked was several years ago, but Pioneer Porsche could still get them for me then.
    An alternative is to fit the later rear rotor and give up or modify your parking brake. That is really the only difference- the hat for the parking brake drum is a different size, I believe.
    At 10.3mm, Harry's rotor must be the early solid type, not the "S".
    TT
    Tom Tweed
    R Gruppe #232
    Read my surf novel!
    Apr 2003
    Portland, OR
    TT
    Correct. Early solid type.
    Harry
    Member #789
    2009 MB C300
    You can take an Early 944 rear rotor and cut about .060" off of the outside dia. and bolt it right up.
    If I use the turned-down early 944 rear rotor does the handbrake still work?
  1. 67/68 vented rear brake rotors
    By gled49 in forum General Info
    Last Post: 11-16-2013, 05:22 PM
  2. RSR brake rotors
    By typ901 in forum For Sale: 911 Parts
    Last Post: 04-20-2011, 07:58 AM
  3. FS: NOS 917 brake rotors / RSR
    By typ901 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 06-22-2010, 08:16 PM
  4. WTB Vented brake rotors, front and rear, 1972 911T
    By M491 in forum For Sale: 911 Parts
    Last Post: 04-03-2008, 04:19 PM
  5. 67S rear brake rotors
    By Rick Cabell in forum Technical Info
    Last Post: 01-03-2006, 09:19 AM
