Results 1 to 3 of 3
Thread: Ignition problem
    Ignition problem
    I am a fairly new owner of a 1973 911E and I'm having an ignition problem. When I insert my key I can turn the key far enough for the radio and headlights to go on but no further. I can't get the car to start because I can't physically turn the key to spark it up. I've tried three different keys so I don't think that's it, and I've tried a little lubrication with no luck. Any suggestions?
    D. Goodwin
    Apr 2003
    Portland, OR
    Re: Ignition problem
    D. Goodwin
    What have you tried as a lube?
    My '73 ignition switch became very difficult to operate. I spoke with my locksmith who sold me a can of "Trilube". After two applications, I won't say it is like new, but the phrase "almost like new" leaps to mind every time I start the car. I asked him why this was the stuff to use. He told me that other lubes commonly used (like WD-40) work for a while but leave a residue that hardens and eventually gums everything up. Supposdly this lubricant does not have that property. Time will tell.
    Good luck.
    Harry
    Member #789
    2009 MB C300
    Re: Ignition Problem
    Thanks, I'll give that a try.
    DGoodwin
  1. Possible problem
    By frankmar in forum Technical Info
    Last Post: 02-20-2013, 01:00 AM
  2. ignition lock removal problem
    By RSTarga in forum Technical Info
    Last Post: 12-31-2010, 05:06 PM
  3. PM problem
    By Cliff in forum General Info
    Last Post: 12-13-2010, 01:08 PM
  4. Problem...3.0 RSR
    By cyber2213 in forum Technical Info
    Last Post: 08-31-2010, 03:22 PM
  5. Pertronix Ignition Problem?
    By 66-68shelby in forum Technical Info
    Last Post: 05-25-2006, 05:23 AM
