Thread: carb rebuild questions...
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    Angry carb rebuild questions...
    OK. just went trough both IDAs on my 67S. There are discrepancies in the 3 different documentaions I have on this carb though. This is all regarding o-rings on the idle jet, and on the air mixture screw. There were none on the carbs when I took them off, and they have seemed to run decent befor the rebuild. What to do? Do I put them back together as I saw them? Do I place an o-ring on both, just one? I don't know??? Out of three books or diagrames: 101 projects Vol 2, Weber Performance Handbook, diagram from the rebuild kit, and an old weber manuel from '77 I had laying around, they all show different combinations of the above.
    Michael
    72 911S Coupe, Sepia Brown
    Check out this Link
    Michael,
    Here is a link to a Pelican parts thread that discusses carb settings. It should help you quite a bit.
    http://forums.pelicanparts.com/showt...hlight=jetting
    Good Luck
    Re: carb rebuild questions...
    Sorry to hijack your thread but anyone got a procedure on how to tune and balance IDA carbs? I'd like to have a go at it this weekend.
    Thanks.
    Sprint.
    Goldmember ttweed's Avatar
    La Jolla, CA
    Re: Re: carb rebuild questions...
    Check out this link
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Re: Re: Re: carb rebuild questions...
    Originally posted by ttweed
    Check out this link
    TT
    Thanks Tom! Very good stuff he has there! Hehe... I got something to mess with this weekend! *wink*
    Have a nice weekend too!
    Sprint.
  1. weber carb rebuild
    By TZombek in forum Technical Info
    Last Post: 11-07-2012, 06:21 AM
  2. Carb Rebuild Service
    By 50/50 in forum Technical Info
    Last Post: 09-02-2011, 05:01 AM
  3. Fuel system rebuild questions (early Weber)
    By ralfabco in forum Technical Info
    Last Post: 07-23-2007, 11:30 AM
  4. Weber rebuild questions
    By Davz912/911 in forum Technical Info
    Last Post: 03-19-2007, 01:52 PM
