Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: engine leaks...
  1. #11
    Yes, it was nice of you to split your case for us!
    1970 911 T
    1977 911 S
  2. #12
    Re: re leaks and momo install
    Originally posted by joelrkaplan
    ...tried to put MOMO wheel on today......hub does not seem to go on all the way like oe wheel so there is play on column....do I just need to push momo hub on harder?....also, my oe set up has no horn wires...how do I hook up horn w/ wires from momo set up?.....would hate to have to pay to get this simple job done...thanx again
    This is kinda going off topic, but the Momo hub is a bear to push on the first time. If you don't have a wire in there to hook up to, something is missing. PM me or start a new thread for more details.
  3. #13
    Hell, they all leak. That's how you know they have oil in them!
    Or, was that for British bikes only???
    Tom
    Early S Registry #235
    rgruppe #111
  4. #14
    joelrkaplan
    Guest
    leaks/momo
    as I had hoped this mb is wonderful(just like Z3 coupe mb)......I will keep an eye on leaks for now as I do not want to open case yet......will go to garage tomm. and try to get momo hub on deeper...will also talk to R and W(momo supplier) to get more install info......will update......thnx
  5. #15
    Time to fess up.
    The timing was right on the oil leak question. I had just buttoned up the botttom end of the motor when the next day I noticed a couple of new intermediate bearings sitting on the counter in their plastic bags. Dooh!!!
    I forgot to put them in the left side of the case.
    Bobby
    71' Olive 2.2E Targa / Early S #491
    I've always considered the glass to be half full...that is until I reached middle age and realized that it is actually half empty.
  1. Replies: 2
    Last Post: 02-22-2013, 12:02 PM
  2. OIl pressure sender leaks, PN 901.741.551.01
    By caproader in forum Technical Info
    Last Post: 04-12-2009, 03:22 PM
  3. Oil Leaks?
    By A.T. in forum Technical Info
    Last Post: 12-14-2005, 07:52 PM
  4. Oil Leaks
    By Gavin English in forum General Info
    Last Post: 05-12-2005, 04:19 PM
  5. Oil Leaks
    By philip guiral in forum Technical Info
    Last Post: 04-12-2004, 08:01 PM
