Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Thread: Collective Wisdom Sought
  1. #31
    I don't know how I got hooked on the originality thing, but I say don't bore out your original case. More displacement is great, but keep the original case under the bench.
    I faced the same dilemma when I did my 914-6. Many folks bore these out for 2.2 pistons, but I just couldn't do it.
    Lee
  2. #32
    That's why I started with a 2.2S and STROKED IT!
    I'm in the process of collecting parts for my next motor, a high compression, MFI 2.7S.
    -Marco
    TLG Auto: Website
  3. #33
    Question 245 HP?
    Respectfully, I would like to know what tricks you are going to use to get 245 HP out of a 2.7 MFI engine with E cams.
    All the best!
    Roger Grago
    Service Manager, PORSCHE Newport Beach
    R Gruppe #27
    73 RS-T
    70 2.4MFI VW Bus
  4. #34
    And I think you forgot $800 to have your throttle bodies rebuilt by Eurometrix. A rebuilt pump is great if the throttle bodies aren't worn out.
    Don't worry it's just more $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
  5. #35
    I will have to agree with my good friend Roger... 245 seems very optimistic
    Of course the dyno is the only way to know for sure, but , like the factory, I like to be a conservative when it comes to HP figures...
    I have now about 575 break-in miles on my 2.4S -to- 2.7RS/9.5 conversion (500 miles with a 5000 rpm limit and 75 of another 1500 miles with a 6000 limit) and I'll tell you, if I once had anything close to the spec 190 HP of the S motor it would seem now with the 2.7 rebuild I have a-hell-of-a lot more under the pedal then before ... mostly TORQUE!!! ... It also seems that the WebCam regrinds want to keep goin forever, so after the break-in 7300 should get pretty damn interesting ...
    All this to say, with all I've done: 90mm 9.5 Mahle RS piston set, WebCams, mild head work, RS spec pump, rebuilt throttle bodies... etc, etc. $, $, $, ...
    If I was to dyno anywhere near 220-225 I would be thrilled...
    Cheers,
    Originally posted by RickS
    The power seems to be excellent, as I can whip any SC (World Dominators that they are) around.
    yeah, but I won't be chasin' rust on my car
    ack! I can hear it now..."heathen! intruder alert! death to the accordian bumpered one!"
    '79 coupe ("early" in spirit...)
  7. #37
    Nostatic went off Pelican? Actually guys, he has a nice SC..assuming there is such a thing.
  8. #38
    be nice Paul...my car is getting "earlier" by the minute. A good concrete whack provides lots of opportunity
  9. #39
    Dec 2002
    Birmingham, MI
    Saw that one... tough luck.
    Ouch!
    Just be glad it wasn't airborne!
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
  10. #40
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    231+
    I put a '75 2.7 built motor in my Heidi's '73 T RS Bastard Evolution Lightweight. It made 231 on the dyno before the SSIs and the B&B muffler (too dam loud!). I think the pipes must have added something to the hp mix over the '75 system.
    RGruppe #183
  1. Replies: 31
    Last Post: 09-23-2013, 05:27 AM
  2. Collective wisdom required??
    By classic in forum Technical Info
    Last Post: 09-01-2012, 07:23 PM
  3. Collective wisdom from the group 1976 Turbo
    By rpsurfr in forum Other Porsche Passions
    Last Post: 09-30-2011, 08:51 PM
  4. Any Wisdom on best car cover to use in heavy snow & sun?
    By 2008SPorsche in forum General Info
    Last Post: 04-08-2010, 11:22 AM
  5. Words of Wisdom from 1996
    By 911s911rs in forum General Info
    Last Post: 12-11-2004, 08:16 AM
