Results 1 to 3 of 3
Thread: Porsche bolt sizes
    Porsche bolt sizes
    I'm having trouble identifying a particular bolts / screw size.
    The parts manual says AM 6x15 screw...it is used for attaching the leading edge of the front door box.
    I've searched the web for a reference to the size as the local fastening supplier does'nt know what it is or an alternative one to use.
    Any help would be good
    Graeme
    The PET shows this as a "half-round screw M6 x 15" for 70 - 73. Is this the correct year range? That should be easy enough to find.
    Nick
    Thanks for the info...thought it would be something like that.
    The parts manual I have says AM6x15 foir some reason and I was a bit confused.
    Thanks again
    Graeme
    73 911S (RHD)
  1. 1971 porsche 911 pressure plate bolt torque specs
    By VaporiZe in forum Technical Info
    Last Post: 09-28-2013, 07:27 PM
  2. Rear Seat Belt Bolt Sizes
    By Irish911 in forum Technical Info
    Last Post: 06-12-2013, 12:43 PM
  3. Replies: 0
    Last Post: 04-02-2013, 07:02 PM
  4. Fan Shroud Clamp, 2 bolt vs. 1 bolt, 2.4 liter engines
    By caproader in forum Technical Info
    Last Post: 12-15-2010, 04:22 PM
  5. FS: Autopower Roll Cage - bolt in, bolt together
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 06-17-2010, 01:01 PM
